What bolt and nut on Ball Joint??
  • s2_bo
    • Oct 2005
    • 6067
    Hello,
    I when to have my wheel alignment done today and it all started off well, The place i used had one of those fancy radio wave guided alignment machine that picks up on just about everything that could possibly be out...
    After about 40 Min's of 3 to 4 of them adjusting the wishbones and cambers
    (It was dam scary letting all those mechanics near the S2 - as they are only used to chaving up kev cars. )
    they decided that the bolt that joins the Ball joint was not the correct one. In all fairness this did not look like an OEM part to me and my only guess is that when i had another garage do the wheel bearings not long ago they replaced the bolt with a standard non hightension one.
    At this point they stopped and said that there was no point in carrying on until i had the correct bolts fitted, as these ones would not last very long etc. so it would just be £60 for 4 wheel alignment down the drain..
    Does any one know what bolts should be used to connect the ball joints at there lowest point? (Ill try to get a pic in the morning of what is currently on there.)
    Thanks in advance..
    Bo
    91 S2 coupé - RIP
    98 S8 - Luxury barge
  • s2dude
    • Nov 2005
    • 1631
    Originally posted by s2_bo
    Hello,
    Thanks in advance..
    Bo
    You mean the one that clamps under the ball joint to seal it in its socket??
    if so I just fitted a standard high tensile stainless Nut and Bolt of the correct diameter (not form Audi)......No Problems with it.......
    What was "wrong" with this bolt?
    • s2_bo
      • Oct 2005
      • 6067
      Yeah thats the one i mean. Apparently the bolt is slightly to thin and threaded all the way through, resulting in weakening, a bit of give, and possible failure in the future.
      (This is what the guys at AMS said anyway.) But then they might have been trying to get out of doing the alignment as it was taking the ages - If others have used normal high tension bolts then maybe it will be fine.
      Cheers s2dude.
      Bo.
      91 S2 coupé - RIP
      • Mikes2
        • 1704
        Depends if you are talking about front or rear and the year of your S2.
        For the front N 010 445 7 bolt and N021 195 5 nut for cars up to chassis 8B-P-008000
        For the front N 034 778 4 bolt and N021 195 5 nut for cars after chassis 8B-P-008001
        Rear uses N 010 445 7 bolt and N021 195 5 nut for all chassis.
        Bolt is M10x1.5. 45mm long and 20mm unthreaded section for the early version
        Bolt is M10x1.5. 50mm long and 24mm unthreaded section for the later version
        Mike
        http://www.s2-audi.co.uk
        • s2_bo
          • Oct 2005
          • 6067
          Thanks Mike!!
          thast a big help, ill get thos bits orderd asap.
          Thanks again.
          91 S2 coupé - RIP
          • s2dude
            • Nov 2005
            • 1631
            Bolt is M10x1.5. 45mm long and 20mm thick for the early version
            Bolt is M10x1.5. 50mm long and 24mm thick for the later version
            S2 Bo// Its only a nut and bolt just needs to be correct size. Audi charge out royally for their
            "speical"bolts.....
            a good ironmongers will sort it
            • Mikes2
              • 1704
              edited with the correct info above
              Mike
              • Corey
                Banned
                • Sep 2003
                • 2793
                "speical"bolts.....
                ??? No they don't.
                considering what the bolt does "any old bolt" will not do especially stainless steel, it may look pretty but doesn't have the strength needed.
                Use the correct grade of bolt, any 8.8 grade of bolt (and make sure it is a bolt with an unthreaded portion where is passes through the stub of the balljoint) will do and be safe in the knowledge that you havedone the job correctly.
                Corey
                01636 822288
                • s2dude
                  • Nov 2005
                  • 1631
                  Originally posted by Corey
                  ??? No they don't.
                  Thats what I meant by matching it up correctly. Though I do have access to a hell
                  of a lot of bolts :mischeif:
                  • Graham
                    • 1622
                    Use a socket head cap screw, they are only ever made out off at the lowest 8.8, then 10.9 then 12.9 super tensile jobbies.
                    • s2_bo
                      • Oct 2005
                      • 6067
                      Thanks for all your input guys.. Stop on as always .
                      Cheers.
                      Bo
                      91 S2 coupé - RIP
