the drain plugs are easy box and diff its the box filler thats a ****** with the drive shaft just below the filler plug there is a small plastic flap on the n/s inner wing thats held on with a 10mm plastic nut remove and use a long 1/2 extenstion bar its will be tight good luck if its the same as a aby box??????????
get your oil from ben o/e is always better think it was £40 for the both
I would reckon you could just about get to the drain plug, but it's the filler plug that is the problem - it's right up in a predictably Audi-esque difficult to reach place at the top of the box, and I would think that you'd struggle somewhat to reach it if you were on stands lying underneath.
Essential not to crack open the drain plug before you've first ascertained that you can safely remove and replace the fill plug.
Originally posted by Fat Audi 80
So what you are saying Dan, is the Drain plugs are easily accessible if you are on your back on the drive with the car on jack / axle stands then?
Cheers,
Steve
