noise from prop
  • Dan_s2_coupe
    • Aug 2006
    • 482
    noise from prop
    just had a look under my car cus i had a rattle and when i twist the prop back and forward there is a rattle sounds like it is inside it tho ne1 know nething bout them
  • Dan_s2_coupe
    • Aug 2006
    • 482
    cheers for the help boys NOT
    • spink
      • 4382
      use the search button,theres loads of info on here.
      oh and ,,,,, and ....... are quite helpful.
      • martinjs
        • 3205
        It could be the cv's at each end of the prop, try holding the flange on the end of the g/box and then twisting the prop to see if there is any play, do the same with the rear diff.
          • 12431
          It could be a worn rear diff. When we were at the garage meet last year ross' car had alot of play in the prop compared to other S2's.
          • Dan_s2_coupe
            • Aug 2006
            • 482
            it seems to be inside the front big of the prop when i twist it
            • Ski
              • 2591
              Nice attitude
              ABY Coupe
              • Dan_s2_coupe
                • Aug 2006
                • 482
                well got peoples attention didnt it wasnt tryin 2 be rude
                  • 12431
                  have you check the centre mount on the prop also?
                  • Dan_s2_coupe
                    • Aug 2006
                    • 482
                    yeah cente mount slightly low but not from that. is there ne thing like anther tube inside prop
                    • s2dude
                      • Nov 2005
                      • 1631
                      What do you mean centre mount slightly low??
                      Is there a silver insulating metal sheet on the underside of your car that is above the exhaust?? It shields the floor from the heat of the exhaust......
                      • Dan_s2_coupe
                        • Aug 2006
                        • 482
                        yeah there is
                        the mount is hangin inside its self if u get wot i mean
                        • panzerwagen
                          • 900
                          Dan you need to look at 2 things here...
                          The universal maybe shot and deflecting all over God's creation down there. Since the prop is metal, it may
                          transfer sound up & down the shaft. If that has happened all ready then the center bearing may be
                          shot too. I'd have a real hard look at the universal.
                          • Dan_s2_coupe
                            • Aug 2006
                            • 482
                            ok kool ill check that cheers
                            • s2dude
                              • Nov 2005
                              • 1631
                              yeah there is
                              You need to remove this metal insulating sheet to get a proper look at the centre bearing iirc...
