just had a look under my car cus i had a rattle and when i twist the prop back and forward there is a rattle sounds like it is inside it tho ne1 know nething bout them
noise from prop
Tags: None
It could be a worn rear diff. When we were at the garage meet last year ross' car had alot of play in the prop compared to other S2's.Originally posted by Dan_s2_coupejust had a look under my car cus i had a rattle and when i twist the prop back and forward there is a rattle sounds like it is inside it tho ne1 know nething bout themGreg
Originally posted by Dan_s2_coupeyeah cente mount slightly low but not from that. is there ne thing like anther tube inside prop
What do you mean centre mount slightly low??
Is there a silver insulating metal sheet on the underside of your car that is above the exhaust?? It shields the floor from the heat of the exhaust......Comment
Dan you need to look at 2 things here...
The universal maybe shot and deflecting all over God's creation down there. Since the prop is metal, it may
transfer sound up & down the shaft.
If that has happened all ready then the center bearing may be
shot too. I'd have a real hard look at the universal.
