I need a clutch!
    I need a clutch!
    While the head is off finding the mystery water leak, I'm going to take the opportunity to do the 6 speed conversion. So as the box is out I think I'd better do the clutch too.
    So I need an uprated clutch, maybe a Sachs paddle clutch if I can get one.
    Any one know where to go for one or any alternatives?
  • s2_bo
    • Oct 2005
    • 6067
    Speak to Aelred. He has some from a new company that sound very tasty.
    I also have a clutch kit that Ant sent me about 6 months ago (Sachs i think), it didn't fit my 3B because the pressure plate came out about 10mm to far form the cover, but your welcome to give it a try.
    If you want it let me know and i can send it to you. Then if it fits or you can make it fit you can pay Ant for it
    Cheers.
    Bo
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • dan_b
      • Sep 2003
      • 3670
      Newsh, what did you do to your car at Combe?! Sounds expensive!
      • Ski
        • 2591
        I got my cluch and flywheel from Aelred. Would highly recommend getting one from him if your dont mind waiting for it as they come from USA.
        ABY Coupe
        • Jaap
          • Oct 2003
          • 258
          Clutch
          I need the same, for the same purpose.
          Foud one in germany for 395 euro's (you need to send the old one) then u become a clutch good for 650 NM
          This is a presureplate and a clutchplate.
          I have not decided yet...
            I just did a few laps in it mate, but it has a drinking problem, lots and lots of water...
            • Corey
              Banned
              • Sep 2003
              • 2793
              Aelred now uses SPEC clutch's, same as we supply. Just make sure you have the metal release bearing rather than the plastic item.
              Corey
              01636 822288
              • aelred
                • Jan 2005
                • 761
                I have a couple of spare ones as some members did want them but when it was time to pay they funds had run dry.
                Aelred
                • Billman
                  • 4129
                  How much do these Spec clutches cost and for what Torque are they good?
                  Go Holset or Go RS4
                  • aelred
                    • Jan 2005
                    • 761
                    @billman I will send specs and costs by PM
                    Aelred
                    • Mihnea
                      • 1288
                      We've only had problems with Spec clutches so far....
                      Sachs race are the best so far, I can do 7k launches with 245/35/18 rubber and get no slip at all, awesome clutch!!!!
                      Just my 0.02.
                      Mihnea
                      www.MRCTuning.com
                      info@MRCTuning.com
                      Workshop Directions
