This steaming pile of s***e. I must have removed and refitted the linkage arm 20 times trying to tweak this thing to work properly and eventually had to give up and go back to the stock bushing. The neighbors must think i have been diagnosed with tourettes syndrome. Can i return it and get those three hours of my life back?
034 Shifter Bushing
034 Shifter Bushing
<p>This spherical shifter bushing Linkage upgrade for the Audi S2/RS2 6-Speed eliminates slop caused by the factory nylon ball socket joint, resulting in crisper, more precise shifting.</p> <p><strong>Features:</strong></p> <ul> <li>Aurora Spherical Bu91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressTags: None
- 1 like
Standard fitment on 034 parts. You will need to actually bend the linkage to make it work, if there is enough misalignment in the joint in the first place (doubt it looking at the picture).
The 034 shifter bush is awful! I ended up buying anothe bearing with more range of motion and tweaking the shifter arms. Here's what i did:
https://www.s2forum.com/forum/techni...r-linkage-help
