Hi all
We've swapped the Dual mass out for a Leanders flywheel and Sachs clutch setup and now sitting with no pedal action. Is it a straight swap or is a spacer required. 1992 urs4 with 01E box. Or is it just a bleed issue?
I havent heard of the leaders flywheel. When I changed my dual mass to a single mass on my ABY with Sachs clutch I had to remove the gearbox spacer on my s2 coupe
I didn't have to make any changes when i installed my flywheel/clutch/pressure plate. It's just bolt on stuff. But what pressure plate do you use? I use Sachs "707" pressure plate
