I'm checking my gear box before riding but I have some problems in it
repair gear box 01e CBL code
Input shaft: 01E311105J
Pinion bearing: 01E311220A
I would propably just change the bearing and leave the other. The first gear issue is just little noise, but you don't drive with the first gear for long periods. Can't see what the other damaged gear is, but does it make noise?
