ABY transmission rebuild
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    Hi.
    My 1st gear was always difficult to select but from yesterday 2nd decided to be as bad or even worse so it's time to start thinking about removing box and replacing synchros.
    my question is,is there special tools required other then usual workshop tools to do the job and once the box is stripped is there any known upgrades I could do to it like installing some parts from RS4 ???
    I don't know,just generally something worth doing once the box is removed ?
    Kind regards
    Pete
  • SteveH
    • 4460
    This will give you an insight into the processes and tools required.
    91 Modded 3B
    14 A6 Avant Black Edition
    • piotr
      • Jul 2012
      • 1470
      Wow-great info.Thank you so much
      • piotr
        • Jul 2012
        • 1470
        Just contacted Audi -synchro hubs NLA Great.
        • jsws3
          • Apr 2012
          • 1174
          Jhm do a carbon coated synchro kit with updated shift collars .
          • piotr
            • Jul 2012
            • 1470
            Cheers ,I will contact them now.
            • piotr
              • Jul 2012
              • 1470
              Or maybe swapping for RS4 B7 would be the way to go with it ?
              • jsws3
                • Apr 2012
                • 1174
                Thsts whst I would do as you will end up spending a small fortune on parts .
                  Probably a cheaper option. From your description Pete I would be surprised if you don’t need a new 2nd gear ratio too. Parts for the 01E are crazy money. Some of the bearings are well over £200+VAT
                  • piotr
                    • Jul 2012
                    • 1470
                    ****.thats mega money.
                    Do you know whats involved in adopting RS4 B7 to the S2 Coupe? im struggling to find staff on forum this days
                      Yes I know a bit
                      • piotr
                        • Jul 2012
                        • 1470
                        Go on then
                          • piotr
                            • Jul 2012
                            • 1470
                            Cheers buddy.i think I will need this in new year .I will PM you
                            • rxl
                              • 1913
                              nice going.. i think newer gearbox will be a better option
