Hello,
I have a 83 Urq build and installing the 01E 6 speed manual transmission. I believe the trans came out of a coupe quattro. Has anyone done this conversion and if so, did you use the stock 01E linkage and shifter? The Urq shifter has a male spline connection to the trans linkage, where the 01E has slotted bolt bracket. I would prefer to use the Urq shifter for ease of install, but something needs to be modified and not sure what to do
Any help would be appreciated.
