Cant change gear
    If the master cyl is going it will probably be weeping fluid, if you listen carefully you may hear a squishing noise when the pedal is depressed.
    If the release bearing is going it will normally be noisy. The Spec clutch kit comes with a new release bearing so it should have had one, these have been known to fail though..
    • Ski
      • 2591
      If the release bearing is going, what sort of noise we talking about, and should i expect this noise when I press in the pedal? or release?
      any info would be very benefitial for me and thanks in advanced to all who replied
      ABY Coupe
