Not hard but expensive. Probably cheaper to fit a 01E with slightly longer ratios already fitted i.e. DSY / FDP out of a B5 S4/RS4
and salvaged a useable unit. Depending on which chassis there may be a bit of a mix&match job with shafts and cv's, after a chat with said wizard I may part and spherical weld front flanges for my project which makes good for replacing parts later on.
would like to see same setup/power drag with tdi&o16. 60mph rpm's too.
