Why does it smell so vile?? I've just changed the oil in my gearbox. Will be doing the diff tomorrow. God i hope the smell washes out
On a more serious note, I managed to fill by about 3 litres. However, i only realised afterwards there are 2 drain pugs??!? Do i need to drain the other one too or will i get away with it.
When i drained it i lowered the front and jacked up the rear slightly just to make sure it was all out.
just wait til you crack the drain plug open on the rear diff.......oil looks baddd and the smell of sulphur is enough to make you gag!!!
