STaSIS diff
  • Acki
    • Mar 2014
    • 302
    Originally posted by hiloran
    Linked timing chart worked for me. If timing is wrong torsen did not turn.
    Washers I used were AS3552 (Old torsen). just relpaced the bronze and needle bearings at the ends. two piece and new B5 E and F torsens use AS3047.
    https://www.dropbox.com/sh/h6jnswfiq...4OPEC-1Xa?dl=0
    Unfortuantly the picture didn't work anymore.
    I have this type of diff (attached picture) and as far as I understood I have to replace one needle bearing and the bronze washer with this AS3552 correct?
    Can somebody confirm me this? Thanks in advance!
    This gallery has 1 photos.
    • hiloran
      • Mar 2010
      • 121
      You have PM. Bronze and needle bearings are bad You need to maintain original thicknesses in place. You can use AS/LS3552 thrus plates and the ones you have in original needle bearings
