i hace just replaced the clutch master following the squeak and snap common to aby
i used a crappy ecp part that wasn't quite right on the threads. i managed to get it to work until i have a proper one but after bleeding the clutch with the pressure bleeder i now get good flow of fluid but the pedal drops and then has around w2 inch of pressure like they are when the piston bends.
any ideas on this.
the piston on the master looks to move nice and straight and it had a good bleed.
does the screw on bit have to be set in a certain position when fitting to the pedal?
could it be a slave or clutch problem
cheers in advance
any ideas on this.
cheers in advance
also have you tryed bleeding the slave as its unlikely but poss. that air has managed to get to the slave cylinder?
