Gearbox removal guide leaving engine alone... (Thanks Aelred)
This is a sticky topic.
  • 20comer
    • Feb 2010
    • 33
    • Home: Portugal Current: United Kingdom
    the idea was doing both at the same time, clutch and rods, but from your words I understand that's not an issue.
    • andy10v
      • 5996
      Yup once the engine is out you can do your rods etc easily, fit the new clutch to the engine and then stick it back in the car, no need to remove the gearbox.
      Sold ABY-stock
        Aye, gearbox weighs the best part of 100kg so make sure you're prepared (and get some mates to help!).
        • smiler131177
          • Mar 2013
          • 45
          I remove my 6 speed last night blood hell there heavy be carefull getting it out 3 of us lifted mine out on your own will be tricky
          • ddo
            • Jul 2014
            • 1
            • Country: Denmark
            #20
            hi all
            having read the above (super/tks) but still experiencing difficulties in getting out/down the gearbox (for clutch change), i would like to know if it is a pull or push clutch system in an Audi S2?
            cheers :-)
              01E clutch activation
              Originally posted by ddo
              ... i would like to know if it is a pull or push clutch system in an Audi S2?
              The clutch pedal pushes on the clutch master cylinder which moves fluid in hydraulic lines to the clutch slave cylinder which then pushes its piston arm out into the clutch operating arm which pushes onto the throw out bearing which pushes on the springs in the clutch pressure plate, which takes the pressure off the clutch disc and disengages the engine from the transmission.
              No pull anywhere in that discussion.
              • saltinot
                • May 2004
                • 1946
                #22
                It is a PUSH clutch. The throwout bearing pushes the pressure plate which disengages the clutch.
                • Kieron20V
                  • Mar 2008
                  • 1505
                  #23
                  Honest question..
                  Neither of you have obviously ever worked on Peugeots haha.
                  1994 URS4 Avant RS2+
