RWD on an s2
  • CoCaine
    • May 2008
    • 216
    • Home: Romania Current: Spain
    RWD on an s2
    Does anyone knows if there will be any problems with the torsen or anything else if I remove one front axle and make my s2 RWD for a lil' bit of playing?
    I`ve seen THIS VIDEO and I want to make some burns and donuts..
    Anyone?
    Many thanks,
    Costan.
  • Mr.Crossfire
    • 145
    Well, you have to weld your torsen solid to do that.
    • iain1067
      • 984
      I personally wouldn't do it, who knows what you will upset, plus i don't think the wheel bearing will last on the axle that you remove, seem to remember something somewhere that cars shouldn't be driven with the axle removed for this very reason.
      Iain
        Speak to Puglife, there is a better method than welding the diff.
        • goodall
          • Jul 2008
          • 810
          you will have weld the centre diff, which destroys it, or have a adaptor made up replace the torsen c-diff to connect the output to the rear drive only
          it looks useless anything less than drifting and like way subarus end up when people do it and audis have even more weight over front axle
          just stick with using the diff lock, unless you want enter a drifting contest....
          im guessing you know you will need keep old outer joints inplace stops wheels falling off
          • CoCaine
            • May 2008
            • 216
            Thank you all for this advices,I won`t do it,AWD is good enough for me
            I will stick to THIS
            • Puglife
              • Jun 2006
              • 731
              Use early Quattro 016 running gear... very simple to make it into RWD..... and its a solid system, with option to completely lock rear diff....
              I've done it, but not in an audi
              Jay - pug_life85@hotmail.com
              1986 Audi UR quattro - WORK IN PROGRESS
              1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
              • Puglife
                • Jun 2006
                • 731
                • urquattro-island
                  • Mar 2006
                  • 1915
                  • Home: Norway Current: Iceland
                  no
                  problem running with the driveshafts removed, just remember to leave the cv joint in there with the bolt, to keep it stable, and not brake the bearing.
                  japanischer industriabfall nein danke!!
                  www.rackeltrim.se Icelandic Division
                  • CoCaine
                    • May 2008
                    • 216
                    How about running with RWD on a DYNO test?
                    In Romania we don`t have a dyno for 4x4
                    Will it be good?How much loss for the transmision?
                      Don't bother. Get a GPS or acclerometer based performance meter and then you can use it time and time again.
                        If you wanted to do a RWD S2 properly then you're looking at modifying the front end and moving the engine back to take advantage of not having a front diff. You'd be well advised to get a 2wd gearbox on there too, both lighter and less complex compared to the S2's torsen and front diff setup. If you put it to RWD as stock then the weight distribution would cause issuses with traction, you'd have to do the old Ford Capri trick of a bag or two of cement in the boot
                        • CoCaine
                          • May 2008
                          • 216
                          Like I`d sed,I like the AWD.The RWD idea was only for fun,to laugh on my e30 friends
                          Thanks to all again,
                          Costan.
                            To join in with E30s you need... an E30
                              best way to do it would be mid mount a 20vt with a fwd gearbox drivng the rear wheels - the set-ups perfect for that on paper, suprised noones done it.
