Prop shaft removal proplems
  • JamesHarrold
    • Feb 2008
    • 245
    You're a legend...
    Just what I needed....looks like I have been pulling the wrong part
    James
    • JamesHarrold
      • Feb 2008
      • 245
      Now in the process of putting it all back together after a winter "overhaul".
      does anyone have the torque settings for the x6 propshaft/diff bolts....?
      Have removed front a rear subframes, blasted & re painted with ally subframe bushes. same with wishbones and rear tie rods, FARB & RARB etc etc and replaced ALL bushes/balljoints/Gearbox & Diff mounts as most were getting tired. Should be a VERY different car to drive hopefully.
      James
      • s2driveruk
        • 12696
        when i replaced my prop recently i just torqued to 'tight' lol not sure on the official value but they need to be on tight, just be careful not to strip the head
        1992 3b S2 Coupe
          IIRC 80nm on the driveshaft to diff bolts and 60nm on the prop to diff bolts
          • JamesHarrold
            • Feb 2008
            • 245
            Great! Thanks...Appreciate the info.
            Regards
            James
            • WidowmakerS2
              • Oct 2007
              • 354
              • Current: Norway
              #21
              Originally posted by mikeraz1
              BUT,
              It was a problem with rounded nuts. I tryed bolt exctractors but they didn't work on the round allen key heads. Then tryed beating them off with a coal chizzle, that didn't work either so they have been cut off.
              I've had some success with beating torx sockets into rounded allen key heads.
              When that doesnt work, I've used XZN's
              Everything goes with the right application of violence and vaseline
              If at first you don't succeed, destroy all evidence that you tried.
              -CQ 3b "S2".
              • s2driveruk
                • 12696
                1992 3b S2 Coupe
                • Acidburn
                  • 13459
                  I found it easier to do it away from the car
                  all mine came off fine so we could strip all the running gear down.
                  Out of interest anyone know what the correct term is for the grease that goes inside the flanges on the diff that the prop and d/shafts bolt to?
                  • gavs20v
                    • Sep 2004
                    • 3057
                    **** me! The hubs are never off are they? Lol the ur is looking good pete
                    S2 Cabriolet.........
                    • s2driveruk
                      • 12696
                      i just thought the grease was the same as for cv joints...a moly grease
                      1992 3b S2 Coupe
                      • Acidburn
                        • 13459
                        Lol everything was off the underneath, good job I took it off found a few worn mounts, its now got all s2 running gear.
