Does anyone knows whether RS2 engine will bolt straight onto 3B gearbox? I'm looking to change my s2 with rs2 engine.Or will ABY gearbox bolt onto Rs2 engine
Answer is yes, but you'll need to fit the 3B flywheel and clutch to the ABY / ADU engine first, or I don't see any reason you cannot use the spacer from an ABY - a few of us have them spare.
The 6-speed box is a good upgrade though as it is stronger.
Need for the spacer is linked to the flywheel you use, not the gearbox. Use a 3b flywheel & clutch = no spacer. Use an ABY standard dual mass flywheel = use spacer. That's my understanding.
,cos i'm after 400+hp power and a 3b will not give me that kind of power without alot of modification.With RS2 ADU Engine,all you need is a couple of chips and 400hp is almost achieve.Bigger turbo like gt3071 and 450hp is almost in sight
[SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
