To renew, remove the top plug first. Then remove the lower and drain the fluid. Then fill from the top plug until the level reaches the hole and replace the top plug.
It is the same procedure for the rear diff too. HTH
Change oil in RS2 gearbox, need help
Hello!
I am going to change the oil in my RS2 transmission, and im wondering. Does it exis an "how to" on this topic?
It's 2 plugs to remove to drain the oil, but only one too refill oil. So when I refill thru the one hole i found to fill, does this fill up both "chambers" ?
Pardon my poor english
Tags: None
