Change oil in RS2 gearbox, need help
    replied
    Originally posted by Greg_S
    On a related note, are the plugs and washers for the gearbox fill and drain readily available?
    Yes, Limebug on eBay £6.25 each
    search VW M24x1.5 sealing plug
    replied
  • Chris5044
    replied
    Originally posted by Mikes2
    A very old post to drag up. The workshop manual for the S2 states 7mm below the filler. 01E is the generic name for manual 6 speed boxes. Lots of cars after the S2 were fitted with an 01E box which is what Paul was referring to
    Sweet thank you. Yes im doing oil now. So needed answers n search brought this up. Yep worked this out on visual comparisions of boxes online etc..thank you for replying.
    Our boxes are same as rs2.. hehe.. also used in early gumbert apollos.. so extra info I found x
  • Mikes2
    replied
  • Chris5044
    replied
    Looking at 01E tranny manual here. It calls out 2.7 liters of fluid.
    On older 01E gearboxes (S2 and RS2) the filler plug is towards rear of the driveshaft flange. Manual states oil level should be 7mm (seven) below bottom edge of filler hole.
    Newer 01E boxes (later than S2/RS2 applications) have a filler plug towards the front... Manual states oil level should be 1mm (one) below bottom edge of filler.
    Anyone know the answer to this?
    this is slight confusing.. does he mean older 01E by 5gearbox? And newer 6speed?
    Or meaning all boxes with s2 n rs2 are old?
    As he put later than s2 rs2, is that a typo? Were these boxes used after s2 n rs2 in newer cars hence matching what he is saying?
    I have a 6speed aby.. so its either 1mm or 7mm from fill cap... ahh!!
    Please help xx
  • prosty
    replied
    I've always filled the gearbox until it flows from the fill hole, it always runs down a bit on the gears so when it flows through the hole, it "should" be enough, never killed a tranny because if this anyway (AFAIK)
  • lind4hl
    replied
    it feels weird that it should sit 7mm under the plug.. i will try my car with oil level @ the plug anyways, but i might have wrong, but it doesent feel right..
    replied
    On the rear diff, oil level is conveniently at the bottom edge of filler plug. Capacity of 1.5liter there.
    replied
    replied
    This is curious... checking the almanacs here......
  • lind4hl
    replied
    Jamo and s-express: where have you get these from, i asked my mate that work in the workshop @Audi if it was like this, and he said no...
    i am also unsure on this, why should an rs2 have lower oil level than an s2? if the oil level should be below the hole to fill, why the hell did audi put it 16mm above the oil level, that´s just silly..
  • Lighthouse
    replied
    Thanks everyone! We eventually figured it out, and then understood how it was
    Freshmen still learning
  • AndyP
    replied
    This maybe a daft question, but why does the Avant take less oil than the Coupe? Surely they use the same gearbox?
  • S-Express
    replied
    Originally posted by Jamo
    Hi the fill level is 7mm before the reaching the gearbox hole, you can use an allen key as a marker
    http://www.s2forum.com/forum/showthread.php?t=20384
    Shame on you Jamo its 16mm below on an RS2......:mischeif:
    replied
