This problem is likely your syncromesh for 2nd gear. You could risk a second hand box and hope it does not have the fault, or you could buy a new syncro, IIRC it will be a syncro with gear, and replace it.
The problem is unlikely to be because you don't have the wide 1st IMO
From CGR to CRB gearbox upgrade
Hello, yes I have this problem between 1st & 2nd at high revs.
AlessioLeave a comment:
Does it grind between 1st & 2nd at high revs? Is it not the clutch pressure plate on it's way out?Leave a comment:
Hello, I had ask about this because on my S2 I have a problem if a make a quick passage from 1 to 2 gear with high rpm of the engine, I know that this is a common problem on S2 and RS2 because I know some other people with this problem and I thin that in the past Audi warranty resolve this problem, so I think that is best if a change my CGR gearbox with a CRB.
Thanks a lot!
I was promptly told on here the late boxes had the flexible shaft as well.Leave a comment:
Agree with Paul. First try to break the small first gear on the CGR. I did not yet manage to do that
Is possible to find which CGR,s have the wide first gear or not? Thanks a lot!
The casing is different to accommodate the wider first gear on the CRB(if that's the right box) from what I've seen.Leave a comment:
I ask this because I want know if change only the first gear or also che gearbox box change or what, because is possible to open a gearbox and upgrade it sometimes, but I don't know about the CGR to CRB, is only a question. Thanks!
Bye
