Thanks a lot!
Bye
Alessio
From CGR to CRB gearbox upgrade
Hi Alessio
Have a look at http://www.elektro.com/audi/01E/ to see what you can learn there - perhaps you could email elektro for some advice.Leave a comment:
UP
For resolve my problem I must change only 012 311 247 F synchronizer ring or I must change 01E 311 239 H synchronizer body?
This week I will open the gearbox
Thanks a lot friends!
AlessioLeave a comment:
Thanks a lot Andy!
Thanks!
AlessioLast edited by Audi-Porsche Avant RS2; 9 July 2010, 10:56.Leave a comment:
Hello friends, is possible to change 6 speed ABY linkage with the gearox mount on the car or not?
Thanks a lot!
Bye
Hello, please someone can tell me if for resolve my problem I must change only 012 311 247 F synchronizer ring or I must change 01E 311 239 H synchronizer body?
Thanks a lot!
Bye
Hello, please can you post it the codes of the parts that I must change for resolve the problem?
Is only 012 311 247 F synchronizer ring or is 01E 311 239H synchronizer body?
Thanks a lot!
Bye
Audi should be able to sell you a syncro yes. It will not be the pressure plate you are correct.
The syncromesh - Basically when you are in 1st the engine and gearbox input shaft are doing a set speed to do that road speed. When you want to change up to 2nd, doing the same road speed, the input shaft need to turn slower. When you press the clutch to change gear the input shaft doesn't slow down in the 0.5 of a second it takes you to change
So the syncro does what the name says, it sycronises the speed of the two cogs so the can mesh together. It is basically like a clutch for the individual gears. It is usually 2nd gear that goes because this is normally where you are trying to quickly change gears thus putting more wear on the gears.
I hope that helps you!Leave a comment:
Hello, I have already another gearbox, but I don't know if have the same problem or not, can I find the original syncro from Audi dealer?This problem is likely your syncromesh for 2nd gear. You could risk a second hand box and hope it does not have the fault, or you could buy a new syncro, IIRC it will be a syncro with gear, and replace it.
The problem is unlikely to be because you don't have the wide 1st IMO
I think that the problem can't be the pressure plate, because I have this problem only when I go up very fast from 1st gear to 2nd gear and the engine run at high rpm.
Glad to help.
Bought the manual,because someone on here was selling a damaged(cheap) CGR box.
Got manual,contacted guy about box.GONE.
Atleast someone,s got abit of use out of it.
Karl.Leave a comment:
