Clutch choices from Sachs? for 450bhp?
  • rs2coupe
    • Oct 2004
    • 1782
    • Home: Trinidad and Tobago Current: United States
    I wanted to start a thread to find the best combination clutch/flywheel and pressure plate for my RS2 20vt project. My power goals are max 450bhp
    Should mention rear diff will be swapped for torsen and center diff will be swapped for stasis torsen.
    I want a comfortable and standard feel in the clutch as possible.
    So far reading the threads on here the choice seems to be Sachs. My car will be used on the streets and freeway so nothing radical. I want maximum grip and comfort.
    Wouldn't mind loosing some unsprung weight so considering aluminum flywheel.
    What should I be looking to buy ?
    What is organic and do I need it ?
    Who is selling the parts? links?
    I am not an expert at these sort of things so please bare with my ignorance on the topic
    Cheers mis amigos,
    _Anton
  • A80Avant
    • 10873
    • Country: Greece
    sachs organic will be able to do the job and keep the feel practically stock
    • rs2coupe
      • Oct 2004
      • 1782
      Thanks for the response.
      What pressure plate and flywheel would you recommend with the organic clutch?
      Cheers mis amigos,
      _Anton
      • A80Avant
        • 10873
        • Country: Greece
        stock should be fine,although pressure plate comes from sachs as a kit
          Pressure plate must be Sachs not stock, the stock won't handle it long term.
          Don't go alloy flywheel, a good lightened single mass will do just nicely.
          I've sent you a PM as your based in the US Southbend clutches are a better alternative
          • AndersS2
            • 1364
            • Home: Norway
            You dont want aluminium flywheel if the car is to be used as you say. Ive been through this myself, and now I went the custom SM flywheel route with sachs Racing Dv.ment DM clutch kit.
            Keep the weight down, but not lower than a OEM 3b SM flywheel, and you will get a good revving car with also the ability to keep the momentum when going off throttle and when driving in steep hills (street/freeway driving).
            Just a free tip, but you must go your own way ofcorse.
            Anders - S2 Avant Clubsport - 8pots or die!
            • karlblues2
              • Jul 2004
              • 402
              • Home: England Current: Australia
              Does anyone know the link for Sachs clutchs?
              Google was not my friend
              Karl
              Oz
              Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
              Audi 90 Quattro 20V 1989 7A
              Audi TTRS 2010 APR stage 2 +
              Triumph 675 Street Triple R
              • gedu
                • Feb 2007
                • 295
                http://www.sachsperformance.com/EU/index.htm
                No, not "straight from sachs", that is a dealer website, but I haven't seen them anywhere cheaper
                All quattro products have been dermatologically tested, and are safe for daily use.
                • Jonas_R
                  • 3781
                  • Country: Denmark
                  Could you elaporate on why he should not use a aluminium flywheel?
                  Sleeper S2 Avant +450
                  A6 Avant 2.7t Stage 3
                  Audi S2 Coupe RS2'ed
                  • AllarN
                    • Feb 2007
                    • 151
                    Stock organic and the 707 pressure will fix it, stock flywheel as well.
                    • Faheemo
                      • Feb 2005
                      • 544
                      • Country: South Africa
                      Dont waste your time with Aluminium flywheels.
                      Too light and does not hold enough momentum for power launches.
                      I got my aluminium flywheel as a doorstopper in my garage, took it out and used a 7a single mass flywheel. (Ill sell it cheap if you want! )
                      I had alot of problems with Spec clutches - now i use a Sachs Race setup.
                      No problems - 11 sec 1/4Mile times - smokes the tyres off the line !
                      S2 Coupe fully built.
                      10.9 1/4mile 0-100 in 3.5secs
                      Precision 6262 turbo
                      The Green Monster
                      • Jonas_R
                        • 3781
                        • Country: Denmark
                        I already have the alu flywheel and was planning to put it on because I think the previous owner have installed a dual mass flywheel from the early 5 speed UrS4. But if it is that bad I might not install it.
                        What do you mean by?
                        "Too light and does not hold enough momentum for power launches."
                        • karlblues2
                          • Jul 2004
                          • 402
                          Thanks gedu
                          Much appreciated
                          Karl
                          Oz
                          • s2tommy
                            • Apr 2009
                            • 169
                            hi i hav just found a company called tecnicluth uk and ordered one of there organic clutch kits which is rated for 404 nm of torqe hopefully should have it 2moz. they also do a padel clutch kit which is rated at 510 nm of torqe. anyone heard anything about these clutchs????
                              Search the forum and google, bad choice!
