Some clutch tech specs you can see on Sachs webcat Sachs/Boge/ Lemforder/ Sachs Performance web catalog
Any Experience with Clutchnet???
I have a 3B clutch assembly in the garage, wont be able to measure it until tomorrow. I can take a few pics to allow you to compare. Clutchnet have a habit of supplying the pressure plate from the 200 when ordering the 3B version. You can tell immediately if you have the wrong one because the mounting area where the springs attach look different.Last edited by SteveH; 29 September 2009, 20:56.91 Modded 3B
14 A6 Avant Black EditionComment
yes do it please. I would like to compare it. dont know where the difference with the 200 one is. I gave them the sachs numbers so they figure it out for themselves.I have a 3B clutch assembly in the garage, wont be able to measure it until tomorrow. I can take a few pics to allow you to compare. Clutchnet have a habit of supplying the pressure plate from the 200 when ordering the 3B version. You can tell immediately if you have the wrong one because the mounting area where the springs attach look different.Go Holset or Go RS4Comment
I've taken some pics and will upload them as soon as I can find the time this evening. I have checked the picture you've taken and it's definitely the same as the Sachs and Spec pressure plates. The 200 pressure plate as cutouts around the rivets that attach the diaphragm springs to the cover. Clutchnet and Spec just re-use old LUK and Sachs pressure plates.91 Modded 3B
Here u go....91 Modded 3B
Good question!
Providing it's got the correct diamater and tooth profile it should be fine. The issue I've seen has been with the pressure plates, not the friction disc. I had the carbon/organic sprung disk and it was ok. Slipped a bit, but I know Tom got on ok with his and it lasted well.91 Modded 3B
Ok, clutchnet came up for the fault with this:
And a question now: What is it with this plastic release bearing? Is it ok to use with this thick pressureplatte? The release bearing they sent me is a Sachs!Attached FilesLast edited by Billman; 15 October 2009, 12:11.Go Holset or Go RS4Comment
Use a metal release bearing if you have one. I'm sure others on the forum can tell you how they got on with the plastic faced bearing. I think the Spec clutch I have also comes with a plastic faced bearing too.91 Modded 3B
