Hi,
So about to convert my 5-speed to 6-speed.
Sofar this is the componenst that I have:
- 6-speed box
- gear linkage from 6-speed box
- Brackets to fix the gearbox from 6-speed
- Gear mechanism from 6-speed
- Gearknob from 6 speed and leather sack.
- New needle bearing for the flywheel.
As far as I have been able to read on the forum. I need to do the following when converting:
- Push back the propshaft 1-2cm.
- Make a small spacer that is 30mm outer diamter. But what is the thickness? I'm reading suggestion from 20, 25, 30mm? Also whta should the bolt hole size be in the spacer? I'm doing this to avoid using a new subframe?
- Should I change the slave cylinder while i'm at it?
- Also I have seen AndyP mentioned something about a new clutch hose, thus this have a part no.?
Anything else I'm missing?
- 6-speed box
