Hi,
So I'm just wondering about something.
I'm changing my gearbox tomorrow and my propshaft as well.
My plan is to remove the old grease in the gearbox where the driveshaft and propshaft connects.
I have grease in the driveshaft rubber thingy (dont know the english word) at the moment, since they where change resently, but how much grease should I put in there? I mean some of the grease is transfered to the gearbox.
Also since I will be removing the old grease from the propshaft, how much should I put in there? I mean do I just fill up the rubber thingy with grease or what?
The factory manual specifies to pack the boot with (50g) and the joint with (40g) with the supplied grease.
