Dont know much about UR's but i believe your car originally had a needle bearing mounted in the crank shaft vs the middle of the flywheel on a 3B/ABY/AAN. So the flywheel listed should be correct for a WR/016 combo, but i dont know if you can mount the needle bearing in the AAN crankshaft and use it. Other consideration is a possible difference, or lack of timing pins on the flywheel to drive the AAN ECU sensors.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
