alloy flywheel
  • turbodriver63
    • Apr 2010
    • 373
    • Home: Ireland Current: United Kingdom
    alloy flywheel
    Im building a 400bhp 20vt (AAN) in my 84 ur quattro.
    I intend to use the standard 016 gearbox with an uprated clutch.
    Will this flywheel suit my build?
    http://cgi.ebay.co.uk/AUDI-UR-QUATTR...es_CarParts_SM
    Any help appriciated
    84 URQ 20VT
    95 avant 80 TDI
    87 CQ
  • mcandmar
    • Apr 2004
    • 5118
    Dont know much about UR's but i believe your car originally had a needle bearing mounted in the crank shaft vs the middle of the flywheel on a 3B/ABY/AAN. So the flywheel listed should be correct for a WR/016 combo, but i dont know if you can mount the needle bearing in the AAN crankshaft and use it. Other consideration is a possible difference, or lack of timing pins on the flywheel to drive the AAN ECU sensors.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • turbodriver63
      • Apr 2010
      • 373
      not to worry.
      Worth a try
      I mite be better off just buying a new one from 034.
      84 URQ 20VT
      95 avant 80 TDI
      87 CQ
