clutch for 650hp 750nm rs2
  • prj
    • Mar 2010
    • 6308
    Originally posted by brider
    thank You for reply!
    but could You give url on You clutch and how many hp Your car has? i don't see on the graphic.
    thanks a lot
    Кв в лс переводить не умеешь?
    Graph shows 427kw, so it's 570 hp, don't know if it's from wheels or not.
    This graph is from a G-tech though, so should perhaps be taken with a grain of salt.
    Although if the car runs 10's, it's probably quite right.
    • brider
      • Aug 2010
      • 31
      i can convert kw to hp - but question is that i can't see what's the measure unit.
      10 second it may be 1000kg car with 550 hp... so the clutch may start slip on 550 hp in 1700 kg car.
      • prj
        • Mar 2010
        • 6308
        His car is around 1400-1500 I think.
        Sachs race is a good clutch. I can ask around on when it starts to slip - some of my friends have used one on their drag cars.
        • brider
          • Aug 2010
          • 31
          how do You think - will stock clutch from S6Plus hold 650 nm on 1700kg car?
          • Faheemo
            • Feb 2005
            • 544
            • Country: South Africa
            #35
            my car is full weight car.
            it's probably over weight.
            full interior + rollcage+ big brakes , big turbo , big plumbing , oil cooler etc.
            Only thing that was removed is the aircon compressor as turbo conversion needed space.
            I use road tyres as i've broke the c.v's twice whilst launching the car.
            yes the gtech graph in not accurate as the exact weight is not known.
            But i did a guesstimate of what the car should weight.
            Prosty helped me with the clutch purchase, check his thread , iirc he also ran a 10 with this clutch.
            S2 Coupe fully built.
            10.9 1/4mile 0-100 in 3.5secs
            Precision 6262 turbo
            The Green Monster
            • brider
              • Aug 2010
              • 31
              Your clutch disk - is organic or metal ceramic?
              • Faheemo
                • Feb 2005
                • 544
                #37
                organic , it rides like it"s almost stock.
                I recall the rated torque for this clutch is well below what my car makes.
                but it holds on my application.
                I'm sure prosty's wagon was heavier than my s2 , so maybe it's nder rated.
                The Green Monster
                • brider
                  • Aug 2010
                  • 31
                  ok guys thanks to All
                  next week i try stock sachs disk and pressure plate from s6plus on my 1700kg car with 2 bar pressure and 550 crank power and 600nm
                  and see what happend
                  • Thuppu
                    • 4115
                    How much torque do you think this setup can handle? Fidenza alu-flywheel, SRE 999 754 pressure plate and a 4-puck sinter clutch disc. Does it handle 650Nm on my heavy UrS4?
                    • Masterblaster
                      • Feb 2009
                      • 300
                      Hi,
                      i am using almost the same setup.
                      7A FW+Sachs 707+4 Puck Sinter.
                      With 2,3 bar boost and over 600hp no problem so far.
                      My friend used the same setup with a GTK650 and his clutch was dead meat after 2000KM.
                      cheers
                      Kai
                      UrS4 with Comp CT4367,Vems and other goodies!!!! SOLD!
                      New project Audi S3 with GTX 28/67...
                      http://www.s2forum.com/forum/showthread.php?t=40308
                      • Thuppu
                        • 4115
                        Ok, how much torque on yours, and your friends? I aiming for 550hp so maybe this setup is enough..? Hoping for to use it a bit more than 2000km's.
                        • Masterblaster
                          • Feb 2009
                          • 300
                          depends what are you planning.
                          btw i have a sachs for the urs4 for sale on ebay.
                          should be good for 550nm....
                          cheers
                          • Thuppu
                            • 4115
                            Propably it's going to be more torque. I have now 380hp/480Nm with stock clutch and it has hold quite good. Soon we gona made some uppgrades and engine rebuild, and I hope fore 500-550hp and more likely the torgue going to be something between 600-650Nm. I already settle a deal about the setup I mentioned few posts back.
                            • Faheemo
                              • Feb 2005
                              • 544
                              #44
                              oops sorry !
                              I have 4 puck Sintered clutch on my car , not organic.
                              getting my clutches mixed up.
                              The Green Monster
                                oops sorry !
                                Snap same clutch in my stroker, certainly seems to hold, although I get a bit of clatter
