Upgraded gear/tranny mounts
  • bambridge
    • May 2009
    • 609
    After seeing a few members comments regarding the track/race spec gearbox mounts, regarding being to harsh and causing vibration thro the cabin i have made these ones.
    They are very similar to the hard spec ones i make, but have a poly top hat bush pressed into the delrin cap.
    The idea is to make it slighty softer and reduce any vibration.
    The first 2 are with Brian Tonks and these are going to Will @VRS Northampton.
    Both these guys are going to independently test them, and let me know if they are better or worse that the solid ones??
    The last 2 photos show the poly version with the hard version
    looking good! when are the engine mounts due heh
    • bambridge
      • May 2009
      • 609
      Soon as the 80mm dia poly arrives, then gonna do a sample for testing
        Cool keep us posted
        • blackrat
          • Mar 2010
          • 49
          Look good and watching with interest, what about rear diff mounts?
          • AndyP
            • 6049
            I saw these at Brians last week, the quality was top notch, as usual from Kev
            • Bram
              • Aug 2006
              • 2582
              Looking good. Nice initiative
                looking good, very nice quality gear as usual Kev
                i'm going to be interestd if they're not too harsh
                • Tonks4x4
                  • Nov 2005
                  • 3062
                  Error404 that was a well timed post... saved me searching for the thread.
                  My S2 is the comfy driving car so did not want to upgrade to all solid mounts as when I have been in cars with the solid ones fitted there is a definite rumble and vibration through the car, particularly with high end revs.
                  The spec on my suspension is all standard with the exception of a set of Bilsteins so it was easy to tell a before and after....
                  And the result is........
                  There is a very minor increase in vibration, but no noticeable extra noise. No where near as bad as full solid versions. You can tell that it has also made the gear change more positive
                  so all round its big thumbs up and +1 to recommend
                  Audi Nut!!!
                  • butchone
                    • Aug 2009
                    • 147
                    hi these look good quallity are you selling these? im after a set, bought some track density mounts from 034motorsport.... there rubbish, lasted about 3 months an ripped in two with no returns/replacement
                    • andy10v
                      • 5996
                      ÂŁÂŁÂŁ ?
                      Sold ABY-stock
                      • bambridge
                        • May 2009
                        • 609
                        The second trial set are now with Will @VRS
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          Nice one, Kev.
                          I take it the poly bush doesn't go all the way through the mount, it's just on the top.
                          SS
                          • bambridge
                            • May 2009
                            • 609
                            Originally posted by 4WheelDrifter
                            Nice one, Kev.
                            The poly bush is more of a top hat, its goes thro the delrin, and just touches the ally base, the delrin outer will keep it rigid, well thats the idea
                              nice, I'm interested. Have you costed them yet Kev?
