rear diff seals insertion depth RS2
  • CP951
    • Jun 2005
    • 36
    Hi,
    I forgot to measure the depth of the old seals before taking them out. Now I'm not sure how far the new ones should go in. Any idea what's the insertion depth for both output seals?
  • mcandmar
    • Apr 2004
    • 5118
    I dont have a workshop manual that covers the avant diff specifically but the S4 and Coupe ones tell you to drive the seal in against stop using a specific Audi tool. So i dont know if the tool itself bottoms out to give the right depth or if the seal bottoms out in the housing. You might be able to see a groove worn into the flange that will help you figure it out.
    Either way a small write up and pics would be appreciated as i will need to tackle this job myself in the future.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
      It shouldn't matter, just make sure you drive it in straight and that the seal lip rides on a fresh part of the output flange shaft, or it could weep. Obviously oil round the seal lip when you insert the output flange
      • andy10v
        • 5996
        Mike's s2-audi.co.uk has a step by step guide with pictures on it, its great, I will find the link after work if somebody can't find it.
        IIRC you just put it in straight, but not to the same depth as before in case there is a groove worn in the shaft.
        Sold ABY-stock
        • johne
          • Apr 2007
          • 1406
          IIRC the driver's side is push in as far as the stop ridge. The N/S - the one with the diff lock actuator is 8mm in but I agree with the earlier comments that it wants to go in square far enough to sit on the output shaft flange, preferably on a new bit in case a ridge has worn in. It certainly doesn't want to be pushed all the way in like the one on the other side.
          John
          • andy10v
            • 5996
            Right side against the seat according to Mike's guide.
            Sold ABY-stock
            • CP951
              • Jun 2005
              • 36
              Hi
              You're right. There are grooves on the flange shaft on both sides. I'll need to drive the seals in deeper.
              Thanks very much
