Gearbox identification
  • Jonnybravo
    • Aug 2008
    • 2051
    I've got 2 6 speed boxes, both of which are from late Avants.
    I believe the CGR is the better of the 2 but how can you identify them and if its just a number where do I need to look ?
    Thanks in advance !
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    Maybe one of them has the wide and flexible gear/shaft..?
    • Jonnybravo
      • Aug 2008
      • 2051
      I'm expecting the one from the L Reg Avant is going to be the wide 1st gear one, the other may also be the same but it would help to know exactly how to tell them apart.
      • spink
        • 4382
        look on here,i doubt a L reg car would have a wide 1st though
        • Nuvo
          • Nov 2003
          • 3826
          The code is stamped on the left hand side of the box. It can be found at the 6 o'clock position of the output flange.
          It will read something like XXX YYY YY where XXX is the transmission code and YYY YY is the consecutive serial number.
          • Jonnybravo
            • Aug 2008
            • 2051
            Thanks guys, I'll go and take a look shortly.
