Whineing sound any ideas
  • bilko0795
    • Feb 2011
    • 1883
    Hi lads i have now changed all the wheel bearings on the S2 and i have still got a whine noise coming from the rear of the car, now the bearings have been done it sounds louder than before they were done could it be the rear diff?
    thanks in advance.
  • spink
    • 4382
    thanks in advance.
    yes rear diffs are common for whining,what sort of mileage has it done?best off looking for a cheap 7a one and swap the flanges over,although 7a rear diffs aren't as easy to find as they were sadly.
    • simon20vq
      • Dec 2010
      • 1379
      If you get stuck I have a 7a rear diff for sale, just pm me.
      • driftin jo
        • Sep 2007
        • 2222
        Was your wife on the back seat ?
        • simon20vq
          • Dec 2010
          • 1379
            I was quoted ÂŁ240 to rebuild a rear diff with new bearings, which isn't that bad I don't think. Its quite a bit of work to do at home and the bearings themselves cost over ÂŁ100 quid. At least then you would be sure of a good diff, decent ones are getting harder to find and none of them are getting any younger
            • bilko0795
              • Feb 2011
              • 1883
              The car is on 111,352 miles why is the 7a better than the one on the car is it stronger? whats the best course of action refurb or second hand 7a diff. money is tight at the momment just bought 996 gt3 calipers, ds2500 pads and ml500 discs and bambridge brkts on their way plus goodridge hoses, ouch.
              • benntenn67
                • Jun 2009
                • 859
                Diff whine
                .... Sawdust ??
                Audi S2 Coupe 1995
                VW Passat GL5 (hatch) 1986
                Carrera Subway 8
                  Don't worry Ray it doesn't sound urgent. Try changing the oil that normally quietens them down.
                  The 7A diff is the same as the S2 bar the output flanges and they generally get less abuse than S2 ones so tend to have less wear. Trouble is there is less of them than S2s
                  I would go refurb personally if you intend to keep the car, its another box ticked of things you don't need to worry about replacing again.
                  • bilko0795
                    • Feb 2011
                    • 1883
                    Cheers Alex where would i get the bearings from? i have tried to change the oil cant get the plugs out iv bought new ones from Tps ready but they are stuck tight don,t know how to shift them. The garage that tried have mashed the plugs so can,t even get a allen key socket in there now f---ing nightmare.
                    • pixsaudisex2
                      • Sep 2004
                      • 3110
                      Id never recommend changing the bearings yourself unless you have done a few an have a massive press. Plus like alex says get it done properly and any problems ta
                      ke it back,
                      • AQTdriver
                        • Jan 2011
                        • 750
                        what about tyres? what brands have you got on?
                        i've been working in the trade for a few years now and it's also a common problem - mainly because people buy cheap tyres...
                        '93 S2 Avant breaking
                        '95 S6 Avant sold
                        '83 80 Quattro SWB
                        '85 90 Quattro
                        '85 200 Quattro 10V sold
                        • bilko0795
                          • Feb 2011
                          • 1883
                          The tyres are not the best iv seen they are brand new the last guy put new wheels and tyres on prior to selling the car, one of them wheel and tyre deals,never heard of the brand before.
                          they are called ( sunfull )
                            Sunfull "Ditchfinders"
                            • AQTdriver
                              • Jan 2011
                              • 750
                              They sure are ditchfinders!
                              I would recommend trying a different set of wheels before you buy or replace anything else...
                              '95 S6 Avant sold
                              '83 80 Quattro SWB
                              '85 90 Quattro
