diff bushes and seals
  • jchn_smith
    • Sep 2011
    • 138
    alright im busy replacing my rear diff bushes and seals but im come to a few issues 1st off audi have sold me the wrong seal for the lhd side rear diff output flange. and they cant find the right one does anyone have a part number or know where i can get one
    secondly the bush on the rear of the diff was totaly shot so im not sure which way the bush goes in as the new bushes hole is off centre anyone know which way it goes ie hole nearest to the back or front
    last of all is there any easy way to re attach the diff off the prop as i just split the cv joint to get it off
    cheers john
    ps my car is a aby coupe if that makes a difference
    you have got the wrong rear diff bush, the OE one is not offset, sounds like they've given you one for a URq or Type 85 quattro maybe?
    If so that's probably why they've sold you the wrong seals too!
    diff seals are:
    017 525 400 A [big one]
    016 409 399 B [small one]
    Rear bush (only available complete with alloy housing) 895 599 125
    There was talk that you could get an engine mount off a Mk1 golf that could be fitted to the alloy housing instead of replacing the whole thing.. that might even be what you've got there!
    HTH
    • LHD_Kid
      • May 2006
      • 3697
      diff seals are:
      HTH
      You will be fine using the offset mount, can't remember which way to do it though, but you will easily see by just looking at your existing moun t in situ.
      I *think* it needs to be mounted so the hole is towards the rear...
      If you but a "rear diff mount" from quattrocorner, you get the offset one...
      This does avoid the extra cost of the complete unit in the housing.
      Chris
      • Martin62
        • Jan 2011
        • 187
        John,
        I have just replaced my diff seals as part of my sub frame refurb.
        When I bought the seals from Audi, they told me that there were only 3 remaining of the large one so don't delay in ordering it !!
        Wasn't cheap either.
        Martin
        • Mikes2
          • 1704
          there's an arrow on the diff bush pointing in the direction of travel
          Mike
          http://www.s2-audi.co.uk
          • jchn_smith
            • Sep 2011
            • 138
            all back together thanks for the input. i ended up not doing the large seal after 4 phone calls n no joy. the bush i got was wrong as it was .03" bigger than the bore in the alloy housing got it sorted in the end though was a nightmare getting the diff back on the prop again
            its made a huge difference doing the mounts just makes me realise how badly the other bushes need doing anyone know any decent places to get engine mounts and subframe bushes ( and all the others i could do with doing)
            cheers john
            • andy10v
              • 5996
              Glad you are sorted, its not much fun juggling the prop, the driveshafts, the rear diff mount, getting the side one over and holding up the diff whilst trying to push the exhaust over.
              I got my gearbox and diff mounts from this guy on ebay
              http://www.ebay.co.uk/itm/AUDI-COUPE...item46031cff20
              I did check the price from the dealer first, and bid on a few before I got them for a price I wanted, as sometimes his stuff goes for more than you can buy from the dealer.
              Sold ABY-stock
              • jchn_smith
                • Sep 2011
                • 138
                cool thanks il see what he has
