Hi there. I'm currently building a S2/RS2 from a Audi 80 B4 V6 2.8 Quattro.
The rear subframe is the same as S2 avant/RS2 right?
The front subframe, do I need to change it for the DSY gearbox and the 5-cyl dieselblock?
Also, I'm going to use the 236mm dieselblock with the DSY. Is the DSY bolt on or what mods is required?
Please write too much then too little. Write a lot "good to know".
