Oil cooling for gearbox?
  • Jim_Coupe
    • May 2011
    • 78
    • Home: Sweden Current: Norway
    Hi,
    Im running a Audi coupe turboQ 2.7L stroker for track use.
    I wondering if its neccessary to use oil coolser om my gearbox. Whats you experience?
    Any list of parts needed to build an cooling system ?
    It´s just a question of time..
    http://www.garaget.org/?car=287344
  • Nik0las
    • 1345
    • Country: Bulgaria
    are you runing 5cyl stroker or V6 2.7t?? As far i know easier will be to swap the gerbox with DSY from B5 S4/RS4
      Yeah use a DSY/EDU box that already has the internal oil pump. Then you can just plumb in a cooler - simples.
      • Jim_Coupe
        • May 2011
        • 78
        Aaaahaaa.. I did just discover that the DSY has oil pump stock!! Didnt know .. so there i can just plug in the cooler to the plumbed holes?
        DSY/EDU sound very expensive?
        I runn 5cyl monster stroker.. I sitting here and wondering about what gearbox that could suit my application best? hmmm
        EDU : Gearbox Audi A6 98-01
        • Nik0las
          • 1345
          • Country: Bulgaria
          not sure how expensive it is but some consider these boxes for the strongest for our cars. Here we have car over 1000hp on crank and it is with such box.... This is your only option I would say...
          • Jim_Coupe
            • May 2011
            • 78
            yepp,, the other option is to change gearbox every year..
            • quattrofrank
              • Jul 2010
              • 127
              • Home: United States Current: Norway
              I`m on my 4th season with a stock 01e from a 96 RS2. The oil gets hot off course but no issues besides that. It kinda depends if your going to use it for race or not. If only for trackdays, you run typically 5-6rounds with 1lap for cooling. In racing you will drive for a longer periode and the demands for cooling increases.
              • Jim_Coupe
                • May 2011
                • 78
                Thats true thoug.. I usually run 5-8 rounds on track..
                • Nik0las
                  • 1345
                  • Country: Bulgaria
                  go for DSY everything is bolt on except maybe finding better place for the oil cooller...
                  • Jim_Coupe
                    • May 2011
                    • 78
                    What about the garbox linkage on the DSY
                    • driftin jo
                      • Sep 2007
                      • 2222
                      The standard 6 speed linkage works with it, if I remember right all you need is one spacer washer on one of the gearbox mounts, everything else is just straight swap.
                      I will be finding out soon as I have one in my garage waiting to go on my car.
                      • Jim_Coupe
                        • May 2011
                        • 78
                        Are you guys 100% sure that the DSY i bolt on ?
                        • V6quattro
                          • Sep 2008
                          • 949
                          Yes i have one.
                          • kninio
                            • Aug 2004
                            • 641
                            • Home: Lebanon Current: United States
                            dude i have audi s4 b5 2001 us one , and it have EDU gearbox but doesnt seems to have oil cooler? or am i mistaking? if no can i bolt in oil pump for it?
                              You maybe right, I have never seen one. I was told the DSY & EDU both have the internal pump & fittings for the cooler, maybe it is just the DSY
