Clutch replace..
  • Carfreak
    • Apr 2012
    • 225
    Clutch replace..
    Hi! Just wounder how hard it is to change out the clutch on urs4. Does anyone have a guide to remove the tranny ?
  • yodasfro
    • Apr 2006
    • 129
    Austin
    1992 urs4 1991 200 20v avant 1990 90q 20v
    • Carfreak
      • Apr 2012
      • 225
      Thnx!! Easier than I thought to replace it
      • Carfreak
        • Apr 2012
        • 225
        Another question.. Is it big difference in throttle response between stock dual mass flywheel and the 10lb aluminium one ?
        How much ft/lb does a 707 sachs plate and kep sinter handle ?
        • Carfreak
          • Apr 2012
          • 225
          Is it necessary to change out the dowel pins on the 6-speed tranny or could I just remove them ?
          • yodasfro
            • Apr 2006
            • 129
            There's one on the motor that needs to be removed top left of the bellhousing.
            Austin
            • Carfreak
              • Apr 2012
              • 225
              Thnx
