Hi all,
I have a recently acquired 3B S2 with the usual gearbox noise, and I've just noticed what I thought was the rear wheel bearing might be the diff, as it is leaking oil and is likely to be empty. Long story short, the whole driveline needs work.
I also have a 2.8V6 coupe quattro with engine problems, which I can use as a donor car... The gearbox is in pretty good condition...
The big question is:
will the gearbox and diff from the V6 CQ fit the S2, and what difference to the overall ratio will I see?
Cheers!
Cheers!
