I am currently fitting an O1E gearbox to my 3B engine. I have bought what I believe to be the correct spigot bearing, it fits the nose of the input shaft fine. However the flywheel I have has a 31mm hole bored in it and the outside diameter of the bearing is 24mm? The circlips I have seem to be to fit the 31mm hole?
Is there an off the shelf sleeve that takes up this difference? The flywheel is a billet steel after market one. I did read some where about somebody having the same issue with a fidanza alloy one?
Any help much appreciated
Hamish
Hamish
..i use the 3B item...
