Flywheel spigot bearing sleeve?
  • G60Rallye
    • Dec 2006
    • 1321
    I am currently fitting an O1E gearbox to my 3B engine. I have bought what I believe to be the correct spigot bearing, it fits the nose of the input shaft fine. However the flywheel I have has a 31mm hole bored in it and the outside diameter of the bearing is 24mm? The circlips I have seem to be to fit the 31mm hole?
    Is there an off the shelf sleeve that takes up this difference? The flywheel is a billet steel after market one. I did read some where about somebody having the same issue with a fidanza alloy one?
    Any help much appreciated
    Hamish
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Hy Hamish! There are 2 types off flyweels.
    1 with pressed spigot bearing...and one with ball bearing fixed with 2 circlips.
    I think you have the last type flywheel.
    I can give you the correct part number for the ballbearing.
    All the best!
    • DJones
      • Jun 2005
      • 2020
      Hamish
      It sounds like you need the 7A flywheel bearing, its what you would recognise as a proper bearing as opposed to the one you have.
      Darren.
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        034 105 276 B
        This is the part number...hope is ok...
        • G60Rallye
          • Dec 2006
          • 1321
          Thanks for the replies! I have the bearing with the part no: 034 105 313 A. The flywheel does have 2 circlip grooves in yes. Could anybody confirm the dimensions of the 034 105 276 B bearing?
          • Pirvu Eugen
            • Apr 2007
            • 1978
            • Country: Romania
            I had 1 received with the Spec clutch....but i cant find now....i use the 3B item...
            Iff i find the bearing..i let you know the dimensions..
            I am pretty sure is nothing exotic..
