Hello!
Have some shifting problems with my DSY 01E lately.
Clutch is a Southbend DXD-SS Stage 3 Drag. Clutch was/is fine. Bud after trying some launches i thought it was getting a little sticky. When up-sifting at high rpm te gearbox grinds a little. And on down-shifting it grinded harder.
As i thought is was because the clutch was a little sticky i was driving the car on a relatively normal way
and hoped the stickiness would worn off.
After some driving it got better but not perfect. I did bleed the clutch but that didn't help. Still had some things i would try before pulling the trans but now this hapend:
It shifts really hard in second and first gear. All others are fine including the reverse.
Because it was also with the engine off i did not suspect the clutch. The shifting mechanism is perfect. So i did some resource and found this:
Anyone has any experience with this problem? I never heard off this!
and hoped the stickiness would worn off.After some driving it got better but not perfect. I did bleed the clutch but that didn't help. Still had some things i would try before pulling the trans but now this hapend:
0-200km/h 9sec
. Never heard of it before.
. Glad i tested all the gear before fitting it to the car!
