hi i am looking for a clutch to fit my 1986 200 quattro it needs to handle 550 bhp
anybody know where in the uk i can get one . thanks oh it has a standard 5 speed box its not a duel mass
just find a manufacturer with the right grade of clutch then use their web page to find a uk distributor. helix and sachs can be special ordered through euro car parts and the like, as they deal with oe stuff normally. will have a lead but you dont have to deal with import jazz
bhp is a multiple of rpm and torque so i am sure if you found the formula you could work it backwards
Power [W] =2πn[rpm]/60*Torque [N*m]
So, take engine rpm and divide by 60 [rev/s]
Multiply by 2 times pi (6.28)
Multiply by Torque [N*m]
Divide by 1000 to convert to [kW]
Mulitply by1.34 for [bhp]
It's fitted a Sachs 707 pressure plate with a SRE 8 pucked sintered friction plate on my 4000CS with engine from a 200 20V quattro fitted to the original 016 gearbox.
found these @ 034 motosport http://www.034motorsport.com/product_info.php?products_id=587{43}118 any problems with 034 ? some of you have had problems whats your thoughts
