034 Short Shift
Hi.
We must cut for down the gearknob to put Reverse gear. Only on 6 gearboxes.
And see my pics
I think,that if i have a 5speed gearbox,i havent to cut a plastic bush,but now i am confused.... At 6 speed gearbox is recommended to cut that....Leave a comment:
DeS maybe will be better to make a DIY explanation + pic's for the 5 and 6 gearboxes...I will need some help too.
Mine is here - looks very nice. Thanks again mate.
Up for a good seller.Leave a comment:
??? I did not cut he plastic thing and it still changes gear fine ....mine is the 5 speed gearbox, maybe cut it if you are doing the 6 speed box ? I don't know, but no problems at all after I fitted it , really nice feel to the shift now .Leave a comment:
show me where....thx . I thought,that is plug n play and not bore,cut n play
thats it....BUT cutting the spring ? Don't know why you have to do that ?Leave a comment:
I don;t think you really need the 2 alloy plates, just one would do, its only to give a firm base for the balljoint piece , I put both on only because it would make it a stiffer base....and yes, just a craft knife to carve a little bit off the plastic surround so as to drop the alloy plates into the hole...it will covered up by the gearstick gaiter anyhow, so will not be visible...its a bit hard to explain, but its just a case of jiggling it all about until it is firmly sited, then bolt it up with a couple of washers that ere bigger diameter centre than the ones supplied ( only a little ) bit biggerLeave a comment:
Are u mean this?
so spacers i need only two,and need to little bit redrill...Leave a comment:
Tom,
Slice a little bit of the black plastic at the end that is nearest to you so that the alloy fits into the hole ....it needs a bit of fiddling around to get it flat but it will go in, I managed it even after a night of being totally drunk ! ....the washers were too small for the studs on mine too, but you don't need 4, just get 2 slightly bigger ones....sorry I forgot to take pictures of my fit ....good luck tovarich,Leave a comment:
