6 speed box issues.
  • diesel des
    replied
    do you never drive in the wet?
    Sent from my GT-N7105 using Tapatalk 2
  • Thuppu
    replied
    Originally posted by AndyP
    Never mind the diff....Sunny tyres? Really?? On a 500hp car. You should be ashamed!
    Great tires! Whats wrong with them? Not maybe the best grip, the car was a bit tailhappy on track, but otherwise I haven't had any problems with them. And I have used Michelin, Pirelli, Continental, Falken, Kumho etc. tyres in 18-21" size. Compared to them I wouldn't say these are too bad.
  • quattro84
    replied
    Originally posted by UrS4boy
    No, it is not. The TORQUE SENSING (Torsen) differential distributes torque, it doesn't make more of it.
    It is a multiplier. Multiplying the lowest available input grip to the bias (predefined by preload/friction/ramp angle) to the other end with higher grip angle.
    That's why with one wheel airborne it is useless since there is nothing to multiply.
  • Toph
    replied
    HAHAHA Andy, I noticed that as well...the shame!
  • Toph
    replied
    I stand corrected.
  • AndyP
    replied
  • quattro84
    replied
    Must be shrapnel locking the crown wheel? Since you were able to drive it... If one shaft shears completely or diff crown/pinion explodes you weren't able to drive it unless it is a clean crank held together with pretension like a input shaft/flange to the diff.
    I think you'll see a lot of rounded teeth-less gears... BTDT on a autocross car... still drives in unfailed gears until pieces get locked in and kill the rest.
    replied
    Originally posted by prj
    The torsen is a torque multiplying differential.
    replied
    This is not what happens... seems like it's back to basics on this one.
    Yes, like he is testing this with transmission in first and the clutch out so what you are saying about the front differential, in this case, is wrong. Turning the front wheel that is in the air is turning the transmission which is turning the engine which is getting to a compression stroke on one of the cylinders.
  • prj
    replied
    Whoa. Just a minute. If you have one wheel off the ground and in gear, clutch out and you spin the wheel, you are rotating the engine. "Suddenly lock up" = compression stroke on the engine.
    The front diff on the car is open.
    The rear diff on the car is open, and lockable (except for UrS6).
    With one wheel off the ground:
    1) If it is a front wheel, you can turn it indefinitely, because the diff is open, no torque is transmitted to the other wheels nor to the crankshaft of the engine.
    2) If it is a rear wheel and the diff is unlocked then you can turn it indefinitely, because the diff is open, and again no torque is transmitted to the other wheels, nor the crankshaft of the engine.
    3) If it is a rear wheel and the diff is locked, then it won't turn because the rear wheels are locked together.
    Thomas:
    You broke something in the gearbox and the bits are getting into the gears.
  • Thuppu
    replied
    Yeah, that really could be it.
    replied
    Originally posted by Thuppu
    ...Well, I don't think it's normal to spin freely and then suddenly lock up..? And it shouldn't even spin with the other wheels on ground and the 1:st gear connected I think...
  • Thuppu
    replied
    Barely got it inside the carage. Heard a really loud KLANG sound when I turned in a crossroad after some launch control tests. It was feeling like something hitted the bottom of the car. And then I tried a last launch and BANG, I thought the gearbox was loose or something. It sounded really bad... Treid reverse and GROUCH! But I got it inside the garage driving it.
    replied
    Hmm...I missed the 1st gear part and was thinking it was in neutral. What happens when you drive the car?
  • Thuppu
    replied
    Thomas, I think it is time to set it on fire.
    I have tried but it won't wan't to.
    LOL (Sorry)
    I have no idea what you were expecting but the "quattro" system is NOT a full time all wheels locked-together system. The front diff is a NORMAL open differential which behaves as you see, i.e. with the other wheels on the ground, you can turn the front wheel that is off the ground. That is normal.
    That said, it does sound like you have some slack in the differential crown and pinion gears.
