Hi all, I have just gone out for a spin in my 3b coupe and a whinning noise comming from the gearbox but not in 2nd or 4th gear. I have not used the car for a few weeks now but never heard this noise before, I'm not sure if its clutch or gearbo, has anyone experienced this before?
gearbox noisey in 1st 3rd and 5th gear
Tags: None
i think your gear selector lever is touching something on the chasis when you push the lever forward...actualy...the gearbox lever goes bacwards when you try to engage 1,3 and 5 th gear...
check there first!
goodluck! -
I hope thats the only problem and not the gearbox, I will check that tomorrow. Thanks for your speedy input.Comment
Had this recently last week in fact ! It may be the rubber sleeve under the gear lever mine is torn hence why I could hear loads of grating and grinding noise ! It was in fact the road noise from under the carComment
BUT I DON'T WANT A NEW CAR!
1995 S2 Avant, Volcano Black
2003 VW T4 long nose X pack, (has become project)Comment
