Strongest Shafts for S2
  • Tonks4x4
    • Nov 2005
    • 3062
    Hi chaps I have been searching of late for a solution to upgrading the rear coupe driveshafts after another forum member has recently broken two in same amount of weeks.
    The problem has come using launch control.
    The first breakage was the drivers side rear half shaft
    This weeks breakage was the passenger rear CV
    Now I have been informed there is a way to use the front shafts on the rear with some machining to hubs etc.
    However I just wondered what all the drag strip boys are using to cure this problem.
    If its a reoccurring issue I have been investigating the possibility of having Motorsport spec front and rear shafts manufactured however that will not cure the CV breaking....
    Tonks4x4 - The Land Rover Specialist
    Audi Nut!!!
    The rear CV and splines are smaller, so using front shafts will certainly be stronger.
    CV20v rear shafts are a larger diameter, not sure if they are stronger or not though - the inner CVs are different to S2 ones though 100mm not 108mm pcd so you'd need CV rear diff flanges (easy to find).
    I've seen the rear hub carrier machined out to take an 82mm front bearing in order to fit RS2 hubs. Maybe you can use S2 avant or B5 quattro rear hubs and shafts with that combo? IMHO if you do that the hub really needs a strengthening ring pressing on as there is not much material left once its bored out to 82mm.
    • fish
      • Aug 2007
      • 2335
      Www.cp-service.se has a rear end kit using "flexible" rear shafts and front cv joints.
      • DNA-S2
        • Sep 2012
        • 369
        Situation seems very familiar Tonks
        I will deffo be interested in purchasing a pair
        of rear ones ... Titanium if possible !!
        As I am running out spares or "mates with spares"
        Lol
        Originals are obsolete .. I am up for mods and group buy
        all day long
        Danny
        www.dnaautocare.co.uk
        • terrybullwon
          • Mar 2006
          • 8782
          Like I mentioned you need to use the front hubs in the rears, once this is done I can supply you with a set of custom steel shafts its not a cheap solution but you won't break any more.
          They are £200 each and a few hours machining to the rear hub
          Chef
          • AndyP
            • 6049
            Who's been breaking shafts with launch control?!
            • fish
              • Aug 2007
              • 2335
              http://webshop.cp-service.se/sv/281-...-s2-coupe.html Incl everything you need.! Say hi from Kris if you are ordering.
              • SteveH
                • 4460
                20 odd years of abuse and then launch control comes along. Looks like a common sight recently.
                Front hubs will become as rare as rear driveshafts!
                91 Modded 3B
                14 A6 Avant Black Edition
                • Sleeper_Avant
                  • 2372
                  what about RS4 rear shafts and CV`s?
                  i have all S2 stuff in the back of my A4 and put A4 stuff on my B4 quattro
                  just a thaught?
                  • Tonks4x4
                    • Nov 2005
                    • 3062
                    Is that M300 grade steel?
                    Audi Nut!!!
                    • DNA-S2
                      • Sep 2012
                      • 369
                      I have broken both rear
                      Danny
                      • diesel des
                        • 3896
                        And what price is the Swedish solution landed in the UK?
                        Sent from my GT-N7105 using Tapatalk 2
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          +1
                          • G60Rallye
                            • Dec 2006
                            • 1321
                            Like has been posted its all a bit pointless going to the trouble of better shafts when you still have to use the small outer cv's which rip to bits. I thought the rear hubs had plenty of strength left in them after machining out for front wheel bearings. Its definatly the way to go.
                            Is you friend loading up the transmission before launch by getting the clutch to bite a little?
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              S2 avants has bigger rear CV´s ... so machining + S2 avant CV´s + flexible shafts?
