3B reverse sender/switch
    replied
    Originally posted by simon20vq
    Picture of the reverse sender on a 3B. This is Fused at number 12 15amp. Part number 012919823B
    Thanks for posting. What a strange piece of kit. 012919823B was dropped on March 15, 1989. Strangely the replacement wasn't 012919823C but 012919823A (the number I posted). 012919823A was around from about 1989 to 1997 on the 01A transmissions, e.g. 1997 V6 A6q.
  • simon20vq
    replied
    3B reverse sender
  • simon20vq
    replied
    Will attempt to get to it today and no problem with a photo once removed
    replied
    Great thanks for the help
    When/if you get to your 3B reverse light switch, please take a photo of it so I can steal it ( ) and add the photo and 01A switch PN to this 01E post:
  • simon20vq
    replied
    replied
    No you did not I'm always impressed with your responses! So right side from the drivers seat or looking from the engine bay?
    Left and right are ALWAYS from the driver's seat. So in this case, exhaust side of the 3B. (Don't burn yourself).
    About where the front Item 18 is on this 01E (follow from Item 7 and go to the right on the diagram, by Items 3 and 4):
  • simon20vq
    replied
    replied
    Thanks urs4boy (knew you would come up with what I need)
    I failed. Too 01E-focussed. The 3B with the 01A ARV 5 spd, the switch PN is 012919823A and it is located on top of the transmission above and just the back of the right side drive flange.
    replied
    Originally posted by UrS4boy
    This should be correct.
    Wrong. Similar but different. The 3B with the 01A ARV 5 spd, the switch PN is 012919823A and it is located on top of the transmission above and just the back of the right side drive flange.
  • simon20vq
    replied
    OH....so is it the same location?
  • simon20vq
    replied
  • Kieron20V
    replied
    This should be correct:
    and here (the black and brass one):
    That's an 01E.
    01a as fitted to 3bs is different.
    Sent from my HTC One X+ using Tapatalk 2
    replied
    Reverse Light Switch on Trans - Location and PN
    Hi all.... can someone tell me where the reverse switch/sender is on a 3B 5 speed gearbox. (pictures paint a thousand words if poss)
  • simon20vq
    started a topic 3B reverse sender/switch
    Hi all
    Bit thick but can someone tell me where the reverse switch/sender is on a 3B 5 speed gearbox.
