confused about diffs!
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    Originally posted by quattrostyle
    Since we are talking about diffs now I take this opportunity to discuss the V8 diff option. I'm pretty sure it has been done before but I am a tad lazy.
    I got a S2 5-speed gearbox and diff, what is the real advantage/ reason I would want a V8 rear diff?
    The open needs more grip to one end to get traction at the other output.The torsen concept gets traction with less amount of grip(resistance)at one end.Or it reacts slowly compared to open and it is not spinning only the wheel with no grip instantly.
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      I had a rear Torsen diff and never felt any difference
      But to be honest I never went to the limits with the 575hp on road curves...
      • DamoM
        • Feb 2005
        • 352
        On my standard S2 diff on circuit the car would sometimes spin a inside rear wheel under power whereas now I have more power but it doesn't so it. Given my understanding of what the guys have explained here, I would have thought that as the wheel starts to spin (but still has some resistance), the power gets fed to the outside wheel.
        or I could still not be getting it!
        *1986 ur quattro,2.5 stroker
        *1995 Nogaro Blue RS2,Md357
        *1991 RR 20v quattro
        *2000 Nogaro Blue RS4,RS6 turbos,tubulars,custom 3" downpipes,Miltek,FMIC,big injectors,RS6 big brakes,RNS-E satnav/TV,592bhp/600lbs
        • Ross
          • Aug 2005
          • 3399
          Expect you're spinning up both inside wheels... With my 428hp coupe I found I'd get wheel spin on the front left off a favourite roundabout, you'd feel the diff push power to the back and she's just bite in and go.
          In the wet both inside wheels would slip and it was hard to get the power down. Thats where a Torsten rear diff would have helped. As the corner opened out the car would start to grip and power moved to the rear as the inside got traction, more you get the power down at the back the more it would take - felt a bit RWD.
          • jade
            • Jan 2005
            • 1811
            • Home: New Zealand Current: Spain
            #20
            Originally posted by pasbogdan
            What diff is open?
            normally the front and back Open
            RS 2 580HP
            • quattrostyle
              • Oct 2006
              • 6229
              Okay cool, sounds like it's worth the upgrade then. Will get my hands on one
              • DamoM
                • Feb 2005
                • 352
                They are rare as hens teeth! Quite difficult to fit also, more than a little machining but worth it.
                • DamoM
                  • Feb 2005
                  • 352
                  Yeah that just about sums it up nicely. She just hunkers down at the rear and goes nose up!!
                  • Zoig
                    • Sep 2008
                    • 555
                    Just FYI, the Torsen Rear diff from V8 is a lot weaker then the original Diff, many of them have been killed because of that (WOT when one of the rears is on loose surface and other on tarmac or drag launches).
                    • quattrostyle
                      • Oct 2006
                      • 6229
                      Thought there would be no machining involved with the swap really?
                      • DamoM
                        • Feb 2005
                        • 352
                        So did I but sadly there was...
                          Fits right into a Type 89 diff
                          • andy10v
                            • 5996
                            What car was the diff casing from?
                            Sold ABY-stock
                            • DamoM
                              • Feb 2005
                              • 352
                              [QUOTE=Error404;752746A haFits right into a Type 89 diff [/QUOTE]
                              I know it's annoying!
                              • DamoM
                                • Feb 2005
                                • 352
                                It was from an S2.
