which other audis used a 3b rear diff?
  • s2driveruk
    • 12696
    I'm thinking audi 90 quattro? Any others...?
    Thanks,
    David
    1992 3b S2 Coupe
  • porkkis
    • 1994
    None really, BUT
    All the 5 cyl t89 quattros have the same ratio and internals, just the CV flanges are smaller. I have a tight AEC coded rear diff waiting for install. Just have to take the flanges from the original one and that's it.
    4 and 6 cyl cars have a different ratio so the're no good for us.
    3B and ABY coupe has the same diff. AYV.
    • s2driveruk
      • 12696
      cool thanks.....
      1992 3b S2 Coupe
      • s2driveruk
        • 12696
        anyone know the part number for the complete rear diff?
        1992 3b S2 Coupe
        • WabTheKing
          • May 2004
          • 2567
          do you want one?
          • s2driveruk
            • 12696
            @ WAB: well I am after a tight rear diff as I think mine has seen better days and once the clutch and gearbox mounts are sorted then the only weak link is the rear diff I think causing all the shunt and slack.
            PM me with the details...
            1992 3b S2 Coupe
              David - don't do this - PLEASE - go chase the rear diff of an Audi V8 - yes the VEEE eight. It has a Torsen diff at the back and I strongly suspect that the internals can be transferred to the case of the S2 item. It needs to be done by a proper gearbox man though - lots of funky tools and preload settings required.
              Or if you can simply donate your old rear diff to scientific research that will be even better.
              Between APNess's dead 'box and your dicky diff we have a chance to get some proper investigations done by Lee's contacts at Quaife for LSD's in the form of ATB devices.
              Paul
              • caterpillar
                • 2480
                PARTNR : 017 500 040H for AEC DIFF KOMPL
                ---/----: 017 500 043F for ARS
                ---/----: 017 500 043M for AYV .......8-))
                • porkkis
                  • 1994
                  Hehe, new ones cost A LOT. Say around 5000 euros. Go ahead
                  • s2driveruk
                    • 12696
                    Paul - i was NEVER going to buy a complete one new there are no money trees in the back garden I can assure you!!!!
                    I have a part number from a guy and was looking to cross ref it.
                    I will be replacing mine so you are welcome to the original i should think but i am looking for a complete rear diff to just bolt up - cant be ar*ed with sending it off to be rebuilt. If i can find one which has had an easy life then that'll be fine
                    Cheers for the part numbers Caterpillar!
                    David
                    1992 3b S2 Coupe
                    • Audi Parts Guru
                      • 1317
                      017 500 043M is the part number for the S2 coupe rear diff. It has a ratio of 37/9 and your local friendly Audi UK dealer would be happy to sell you one for £3282
                      S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
                      • s2driveruk
                        • 12696
                        Thats a bargain!!! Well done Audi UK for helping keep another classic on the road
                        1992 3b S2 Coupe
                        • Graham
                          • 1622
                          That is alot when you consider a full S2 6 speeder costs £4511+VAT, and a diff has an awfull lot less labour involved in making one
